Help, Engine Code 6
Old Feb 12, 2003 | 06:50 PM
JDM-B18C-2KHB's Avatar
JDM-B18C-2KHB
Default Help, Engine Code 6
OK heres the deal....
OBD2 B16a2, Swapped in 99 civic ex.
I am using OBD2 B16a2 Comp.
OBD2 B16a2 Wiring harness.
and i had a check engine light, and i checked it by touching the 2 connectors by the ecu, and it blinked 6 times fast.
What is it, what do i do?
Secondary, im missing the front left (opposite tranny side, right by the ac pump), im missing that mount. will it really affect my driving or is it ok? if i drive it do i have to baby it till i get that mount or do i need it? what will happen if i drive without it?
thanks guys.
Old Feb 12, 2003 | 09:44 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
the code is for coolant temp. Probably just don't have something hooked up. And the motor mount, it'll create some good torque steer. I'd get it in as soon as possible. I went for a few months without the lower tranny mount because I couldn't find one, and it torqued steered like a mother...
Old Feb 13, 2003 | 10:36 AM
JDM-B18C-2KHB
i went to honda they said its the air intake temperature sensor. what does it mean?
Old Feb 13, 2003 | 11:07 AM
Tirod's Avatar
Tirod
you are missing a motor mount? yea i'd say you shouldn't drive it or it'll go through your hood..
Old Feb 13, 2003 | 01:07 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
That's some funny **** man! Right through the hood!
you know the other 4 just aren't gonna be able to keep that bad boy under control
Old Feb 13, 2003 | 01:25 PM
dantastic's Avatar
dantastic
cx power!
the iat sensor should be on one of the intake runners. i noticed that on a pic of a b16a2, i didnt see one.. wierd
