Honda-Acura.net (https://www.honda-acura.net/forums/index.php)
-   92+ Civic/EL & Del Sol (https://www.honda-acura.net/forums/92-civic-el-and-del-sol-6/)
-   -   98 civic lx lighter doesn't work (https://www.honda-acura.net/forums/92-civic-el-and-del-sol/501743-98-civic-lx-lighter-doesnt-work.html)
A-TownCivic Aug 25, 2009 11:37 AM
My lighter doesn't work on my car. I have taken the dash apart to see if it was disconnected but it's connected. I checked the fuse and it's fine. It isn't the lighter itself but the plug has no current. any ideas? :confused:
I mainly need it for my gps and phone charger as I enjoy road trips. Could I possibly tap into another "hot" source?
thanks in advance guys
A-TownCivic Aug 26, 2009 01:16 PM
come on someone has to have some sort of knowledge here :dunno:
Line7 Aug 26, 2009 06:28 PM
Do you have a radio installed? In my car I have one fuse for both radio and lighter. Did you check the voltage at the plug with a voltmeter?
You could tap into any wire carrying voltage, but I would just run a wire from the batter with a fuse and through a switch, rather than looking for ignition wires and stuff.
A-TownCivic Aug 27, 2009 01:37 AM
I have a voltmeter but for some reason it doesn't work, or I'm not doing it right. my radio works just fine and I installed that. I'm baffled here with this.
I plug in my cell charger and GPS and neither of them charges. So it isn't getting any juice. I tried to trace the wires to see if they're broken anywhere but they go up into the dashboard.
Line7 Aug 27, 2009 07:08 AM
If you didnt check the plug for current with a voltmeter, you have no way of knowing that there's no juice coming from the plug. Replace the actual socket with a new one. They're very cheap, like $10-$15 at Autozone.
A voltmeter is one of the handiest tools you could have. Replace the batteries on it, use the selector dial to choose the mode that checks continuity and touch the two leads together, the needle should jump or indicator should light up.
A-TownCivic Aug 27, 2009 05:01 PM
i'll do that tomorrow thanks bro :beer:
© 2026 MH Sub I, LLC dba Internet Brands
