HELP squealing noise after car sat for 1 week!
Old Jun 22, 2009 | 12:39 PM
ericgordon123's Avatar
ericgordon123
Default HELP squealing noise after car sat for 1 week!
hey guys, i went on vacation last week, left my car sitting in pretty shitty weather for 5 days. when i first started it up, it kinda puttered and hesitated, then it eventually started to idle fine. but when i reved it past about 2500rmps this weird squealing came from what i think was the engine or maybe on of the belts im not sure. i took it around my block and still did the same thing.
please let me know ASAP of what you think this could be
thanks a lot
Old Jun 22, 2009 | 02:32 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
Sounds like a belt to me. Get under the hood with the car running and see if you can pinpoint where the noise is coming from. If it only occurs at 2500+, just open the throttle by hand.
Old Jun 22, 2009 | 02:36 PM
ericgordon123
so its most likely from the belts but the thing is i cant tell which one because with my civic all the belts are run all together so the sound is coming from all of them..
what could of happened in the one week it was sitting? would the belt need to be replaced?
Old Jun 22, 2009 | 02:39 PM
white_n_slow
it's my D in a B
Well, belts just go bad over time. They have to start squeaking at some point, and it may just be a coincidence that it started squeaking after you were away.
Grab all the belts and tug on them a little bit to make sure they are properly tensioned. You should be able to move it a little bit, but it should feel pretty snug. If they are all nice and tight, then it may be time to replace them. Belts are cheap
Old Jun 22, 2009 | 08:20 PM
Shameinator's Avatar
Shameinator
check the belt that is hooked up to your alternator those are usually the ones that squeak. They stretch over time and csometimes need to be retightened. If its not that then go through the same process with your other belts. Air conditioning belts arew also common squeelers.
Old Jun 22, 2009 | 09:26 PM
ericgordon123
if i took a video of it would you guys be able to kinda pinpoint what you think it would be? i cant tell which belt it is and im hesitant about taking it to a shop and its not the AC either.
Old Jun 23, 2009 | 10:43 AM
Line7's Avatar
Line7
Platinum Member
If you arent experienced checking tension in the belt, you should get a belt tension gauge, or whatever you call it. They squeel because they arent tight enough, or because they are old. I dont think a video will really help.
Old Jun 23, 2009 | 02:12 PM
ericgordon123
update:
so i parked my car in the garage overnight, let it completely dry out in warm garage.. then started it up and let it warm up for about 15-20 minutes and the squealing went away and my cars fine now..
thanks for the input guys
Old Jun 24, 2009 | 09:50 AM
cruzalekz's Avatar
cruzalekz
spray wd40 on the belt one at a time. if the noise disappears, then thats the culprit.
dont spray a lot though.
Old Jun 24, 2009 | 01:01 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
you don't use wd-40 on the belts. Smack smack. It's a good way to make the belts deteriorate quicker. When wd-40 dries it leaves a film on the belts causing it to attract MORE dust and dirt which will cause them to wear quicker AND causes accelerated drying of the belts making them more brittle.
You can use Belt Dressing spray. I have a bottle of it from Pep Boys.
Autocross Help Page
