noob stumped on map sensor issue
Old Jan 20, 2009 | 02:39 PM
darren1984's Avatar
darren1984
Default noob stumped on map sensor issue
Hi guys,
Newbie from Ireland,
Recently b16'd a 95 coupe, everything went good, cars running good, getting a cel code 3 tho, i have gone over my wiring 10 times to be sure, im using a p30 obd1 ecu, colors i have are pink/white(output),yellow/green(VCC1) and green/blue(SG1), I have a skunk2 inlet and throttle body,keep getting a cel code 3 and cant get rid of it, next option i think would be to run 3 wires from the map to the ecu to make sure there is no wiring issues, anybody care to give me some advice? also would cel 3 cause the vtec not to engage as currently its not working,
Thanks alot in advance!
Old Jan 20, 2009 | 02:51 PM
darren1984's Avatar
darren1984
Oh and heres a picture of my baby
Old Jan 20, 2009 | 09:12 PM
cruzalekz's Avatar
cruzalekz
map is one of your main sensors. if its out of comission, your car goes into limp mode and the pcm uses another strategy wherein the pcm actually looks and depends on the TPS sensor. You must fix the map issue since itll affect other emission control systems that you have such as the egr valve.
Old Jan 22, 2009 | 03:30 AM
darren1984's Avatar
darren1984
Got it sorted,changed to a friends map sensor and it works perfectly..
thanks
Old Jan 30, 2009 | 02:36 PM
thetunersource's Avatar
thetunersource
MAP sensor is the key to how all honda engines run. So please change this is you believe it is causing the problem.
