Need Help with Civic Wiring
Old Dec 26, 2002 | 06:38 AM
Enternal's Avatar
Enternal
Default Need Help with Civic Wiring
Im working on the Integra Cluster in my 92 hatch.
I went to this site http://www.geocities.com/Area51/Laby...gecluster.html
However after getting everything wired, the only thing that is being displayed are the high beams :P.
So does anyone know where I can find a diagram with wire connections for the cluster of an integra 3rd and my 5th gen civic?
Thanks!
Old Dec 26, 2002 | 11:45 AM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
you shouldn't have had to rewire anything. I thought they were just plug and play...
Old Dec 28, 2002 | 05:36 AM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
nah the plugs are different. I use to have a site but i cnat find it anymore. I think if i would do a search u should be able to find something. Good Luck
Old Dec 28, 2002 | 06:45 AM
Paul's Avatar
Paul
Eater of Rice
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
It worked for me. Then again I have a 92 hatch and a 97 cluster.
Old Dec 28, 2002 | 07:11 AM
HatchVX's Avatar
HatchVX
I was wondering my freind has a GSR cluster but it has a mechanical speedo and civic have electronic how woudl you hook it up??
Old Dec 28, 2002 | 01:37 PM
Paul's Avatar
Paul
Eater of Rice
I really don't know how.
