Starting Problem Still!!!
Old Dec 9, 2008 | 06:57 PM
Shameinator's Avatar
Shameinator
Default Starting Problem Still!!!
Ok I posted a while back about my intermittent starting problem and you all told me to give my starter a smack and if it started it was the starter. Well I replaced the starter and I am still having problems. Sometimes it starts right up and other times the starter wont click at all. I would assume its my ignition switch but why would it happen only sometimes. If its badits bad isn't it? Any help would be great.
Old Dec 10, 2008 | 12:14 PM
Shameinator
Old Dec 10, 2008 | 10:52 PM
Shameinator
ok so i found the culprit with my starting problems LoL. After replacing a starter that didn't need to be replaced I started messing with the wires that connect to the starter the little one has oil all over it and the connector is a little loose so tomorrows project is to rewire the connector. Its easy and cheap.
Moral of the story: check your wires before replacing anything expensive in your ignition system
