Rim offset Q
Old Dec 9, 2002 | 12:37 PM
DSC's Avatar
DSC
Long way from home
Default Rim offset Q
16x7 +35 good enough for a 2" drop? Thx.
Old Dec 9, 2002 | 12:43 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
People normally go 42mm on civics...
Old Dec 9, 2002 | 12:48 PM
randomtask77's Avatar
randomtask77
Wanderer
I think that you're okay. I have a 16x7 with a +37mm offset and I don't rub. Tire size might be a factor though...
Old Dec 9, 2002 | 01:25 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
+35 will put te top of the wheel pretty close to the fender. You want at least +40(+42 and up would be all the better) with a 7" wide rim and anything more than a moderate drop.
Old Dec 9, 2002 | 05:50 PM
cobbcustomz's Avatar
cobbcustomz
i have 17x7 with a 40mm offset with a 1.75 inch drop. I had rubbing issues in the rear and the front on bumps of anykind. After i got my fender lips cut out and rolled i have very few rubbing problems. BTW i have perfect camber in the front and slightly negative in the rear
