Removing Interior Parts?
I'm trying to remove some interior parts and I'm having some trouble.
In my arm rest the screw don't seem to budge at all, how can I get them out? Also how do I remove the door handle surrounds? |
Hatch might be different, but on my sedan there is a screw that goes into the door handle that you take out. Then you slide the handle toward the front of the car and, on the rear-backside fo the handle you swivel the clip off of the rod and then lift the rod out of the hole on the handle.
Then, there is a screw the comes out vertically from the cup in the arm rest. Next, take the plastic screw and clip out from the front-upper section of the panel. Finally, use a small flathead scewdriver to pop the metal clip that holds the window crank handle in place and slide it off. Then all you have to do is pop the panel off of the door by pulling on it. That's it. :) |
