Hellz yeah, i fixed my A/C!!!
Old Aug 6, 2008 | 02:02 PM
MeanGreen's Avatar
MeanGreen
Default Hellz yeah, i fixed my A/C!!!
5 years later, my A/c works!
Got a new AC compressor, new expansion valve, new evaporator, new o-rings, removed every AC component and line, Flushed and blew them out, added new bits, and Finally this morning dropped it off for an evacuation and recharge.
Hell yeah, now i can drive my black EX comfortably under the horrible Texas sun. Its been over 100degrees here lately.
next project... repaint my front bumper
and eventually
i'd like to get a white civic sedan and put a B16 in that biotch.
Old Aug 7, 2008 | 06:10 PM
remy's Avatar
remy
Yeah...das not bad at all!
Is not easy making the decision of doing something to your car and committing to you!!
Old Aug 7, 2008 | 07:59 PM
Civic2Scooby's Avatar
Civic2Scooby
umm..ok?
Old Aug 8, 2008 | 11:09 AM
MeanGreen's Avatar
MeanGreen
umm..ok?
i think you are referring to remy because i dont understand what 'committing to you' means myself...
So anywho, i got a slight concern about my AC and its effect on my d-series.
I know its going to rob me of HP and so on, but when the AC is on, the engine shakes like a paint mixer! When off, seems smooth as usual. Would this mean maybe the AC belt is too tight? Any thoughts about this? The compressor was brand new. Not a sanden unfortunately.
Old Aug 8, 2008 | 12:05 PM
Civic2Scooby
mine shakes like a truck at idle with the a/c on as well. d16y7
Old Aug 10, 2008 | 02:59 AM
A-series's Avatar
A-series
v-card member alpha
The idle should compensate to some degree when you turn on the A/C(or adjust air&fuel to maintain proper idle), not that extra vibration through the steering wheel and shifter aren't normal. If you turn off the A/C and the revs go up just a bit for a moment, I believe that indicates that the air-control valve is compensating like it should.
