questions on springs
my friend is going to be doing his own coilover setup. since mine was installed so i couldn't help him out too much.
all four springs are the same height. only difference is that two looks thicker than the other two. so which one should be the front? i told him it should be the thicker one, but he's not sure. any advise? |
i do not know.. but it sounds like the thicker one should go in front (since it is heavier up there w/the engine and takes the most beating)
consult the instructions :) |
see if you can see some numbers on the springs....then search for them online to see which is which.
its important you get them right or else the car will look like ass. :D |
THICKER in front since our FWD are heavier there
