valve lash adjustment tips
Old Jul 26, 2008 | 10:27 PM
foosball's Avatar
foosball
Default valve lash adjustment tips
Im going to attempt this on a 95 civic, which sounds very chattery, any tips
Old Jul 27, 2008 | 06:46 AM
fathergoat's Avatar
fathergoat
:3
not really, it's pretty straight forward. just adjust the lash until the low size feeler gauge drags and the high size doesn't go(without forcing it). make sure you check after you tighten the lock nut.
Old Jul 27, 2008 | 08:44 AM
lkailburn's Avatar
lkailburn
college kid
this is a very important step. most people never double check after the lock nut has been tightened and in most cases, they have tweeked the lash during the tightening sequence. so make sure you check it after torqueing.
-Luke
Old Jul 27, 2008 | 10:46 PM
A-series's Avatar
A-series
v-card member alpha
Just throwing this out there, but I found my engine isn't nearly as chattery now that I set the timing correctly. It had been about 1mm away from being set at max. retard the entire time I've had the car, apparently whoever replaced the dizzy didn't bother to set it... or they confused the white mark with the red one.
Not saying you should'nt set the valve lash, but some find that doing that doesn't change the sound much.
Old Jul 28, 2008 | 02:10 PM
thetunersource's Avatar
thetunersource
i always recommend that you take it to a pro for a valve adjustment. ive heard of many people running into problems when diy
