intake help!
Old Nov 15, 2002 | 06:58 PM
truplayboi's Avatar
truplayboi
Default intake help!
i jus got a intake for my 00 civic ex..
okay.. first the intake has two holes but when i removed the stock i had to take out 3 plugs... so which one do i put into the intake im stuck.. if you can help me.. i would appreciate it
thanks!
Old Nov 15, 2002 | 07:21 PM
airon's Avatar
airon
AARONNOJIMA.COM
are you sure the inake you have is for the right year vehicle for one?
sounds like you may have a different year
Old Nov 15, 2002 | 07:22 PM
Tirod's Avatar
Tirod
sounds like a 5th gen intake
Old Nov 15, 2002 | 08:52 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
You probably have a 96-98 Civic intake. 96-98 Civics had 2 "holes" in the intake pipe. One for IAT and one for the crankcase breather. 99-00 Civics have the same two, plus an additional sensor. You can always just drill a hole and use a rubber grommet.
Old Nov 15, 2002 | 09:55 PM
HeavyCivic's Avatar
HeavyCivic
Team HighRev
you dont have to use the hose that goes to the valve cover
just plug in the O2 sensor and the other hose on ur intake
and put a breather on the valve cover
Old Nov 15, 2002 | 10:07 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
There's no O2 sensor in the intake arm.
Old Nov 15, 2002 | 10:31 PM
truplayboi's Avatar
truplayboi
yeah, drilling sounds like something i could do...
thanks alot guys
Old Nov 15, 2002 | 10:43 PM
ManTiS's Avatar
ManTiS
NinJA
:chuckles:
Old Nov 15, 2002 | 11:55 PM
GCEX's Avatar
GCEX
I have a '00 EX and came upon your same problem when I got an intake.
1) Air temperature sensor (correct me if I'm wrong)
2) Head breather (correct me if I'm wrong)
3) Another breather tube that originates from somewhere in the block
I couldn't just leave that 3rd hose dangling off in space b/c I didn't know what it's purpose was (still don't). So I bought a small head breather, connected that to the head, and used the nipple on the intake for the unidentified hose.
You could do the same thing, for less than $20, or you can drill and attach another nipple on your intake, amount unknown, and just attach all 3 things like they would go on your stock intake.
Old Nov 16, 2002 | 06:59 AM
truplayboi's Avatar
truplayboi
Yeah , thats wut i think im gonna do GCEX
