High-Flow CAT vs. Stock CAT
i need to get a new cat converter. should i get a high-flow cat or just put a new stock one on? is there much difference?
Might as well get a high flow one if you plan more mods later on.
Carsound - $48
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1871696168 Just have flanges put on at a muffler shop. |
I have a high flo on my hatch. It's:thumbup:
Originally posted by inspyral Just have flanges put on at a muffler shop. flanges??? what is that? does a high flow cat cause a check engine light? |
Originally posted by Descent flanges??? what is that? does a high flow cat cause a check engine light? http://tech.hybridgarage.com/tech/jdmhdr/cat%2001a.jpg A properly installed high flow cat should not cause an engine trouble code. |
I have a high flow on my car. They are probably cheaper than a OEM Cat or something, cheaper usually than most regular replacement cats I see.
high flow cat won't give you much in performance on a honda
do cats change the sound in any way?
Originally posted by WiLL do cats change the sound in any way? |
