turning crankshaft?
Old Nov 2, 2002 | 06:22 PM
igo4bmx's Avatar
igo4bmx
CockBlockerator
Default turning crankshaft?
I was trying to adjust my valves in my SOHC civic
anyone know how to turn the crankshaft so I can adjust it?
Old Nov 2, 2002 | 11:07 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
17mm socket on the crank pulley. Always rotate counter-clockwise. Take your plugs out and it'll be easier to turnt he crank by hand.
Old Nov 3, 2002 | 05:20 AM
igo4bmx's Avatar
igo4bmx
CockBlockerator
how do you reach it?
jack the car?
Old Nov 3, 2002 | 05:26 AM
Tony96EX's Avatar
Tony96EX
-jack up the car
-remove the driver side wheel
-take out spark plugs (u dont wanna fight compression)
-turn crank pulley with 17mm socket
-good luck
Old Nov 3, 2002 | 09:05 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
It also helps to take the plastic cowling off that goes across the underside of your car. Otherwise you have to stick it through the hole in the cowling.
Old Nov 3, 2002 | 09:24 PM
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
There happens to be a convient hole right where the crank pulley bolt is and your stock tire iron fits in there nicely and fits the bolt. Just turn your wheels to the left and go to town!
Old Nov 3, 2002 | 10:39 PM
dantastic's Avatar
dantastic
cx power!
isnt the stock tire iron 19mm?
Old Nov 4, 2002 | 04:43 AM
ManTiS's Avatar
ManTiS
NinJA
No, 17mm
