lower ball joint
Old Mar 10, 2008 | 08:38 AM
boatwire's Avatar
boatwire
Default lower ball joint
While removing CV axles for replacement, found lower ball joint in rough shape....any advice on procedure to get ball joint out?
Old Mar 10, 2008 | 08:41 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
You can remove the hub and have a machine shop press it out but I prefer my method of whacking it out with a BFH.
Old Mar 10, 2008 | 09:10 AM
raiden571's Avatar
raiden571
turning u inside out
yeah, a big hammer works well. when you put int the new one, take off the boot first, put the ball joint in with a lil more finesse then pack the boot with more grease and reinstall it. they only run about 30 bux a piece for lifetime warranty ones at local parts stores.
Old Mar 11, 2008 | 07:11 PM
boatwire's Avatar
boatwire
Default thanks
I took the machine shop route....and decided to go w/ new upper control arms/balljoint assy's, as well. 96K mi. on the originals is long enough, w/ some washboard dirt roads in the last 10K. They're due.
Old Mar 12, 2008 | 10:44 AM
raiden571's Avatar
raiden571
did you do both sides?
Old Mar 12, 2008 | 11:57 AM
boatwire's Avatar
boatwire
yes...I figured all (4) ball joints got the same 96K miles of abuse
Old Mar 13, 2008 | 07:09 AM
dimich's Avatar
dimich
good for you man. In any case to get the ball joints out there is a tool for that ...
service manual page 18-9
