Caliper Pin Stuck
1 Attachment(s)
The caliper pin on the mount is stuck (#18 on the picture). Can't pull it out, even after hitting with a hammer for a while and WD40.
Do i need to get a new caliper or taking the pin out and putting in a new pin with a new boot will work. Is there any special tool i can use to pry it out? |
can you use a punch to get it out.. and i would try just a new bolt and grease it up right and see how freely it moves if it snags i would replace the whole thing
Punch
What is a punch tool? Can you please post a link/reference to this tool.
I was thinking about using a crow bar. |
What are you trying to do? If you are just replacing the pads you don't need to pull that pin out. It's there just for the bolt to attach to. Also that pin is very weak only takes about 40 ft/lbs of force to strip the threads. I know I did it :)
Pin
Already replaced the pads. Last pads were unevenly worn since the caliper did not slide because the lower pin is seized.
ive found that auto zone should have a socket for that.if not a factory fuel filter banjo bolt socket works well them you find a drill bit that is the next size up from the hole in the caliper then clean the hole in the caliper with it then take the pin and clean it with a wire brush or a wire wheel add some (a little)high temp grease to it then reassemble
Originally Posted by murkho
(Post 3710048)
Put the caliper in a vice. (pick sticking up vertically)
Spray some PB Blaster on it (let sit for about 2 minutes) Use some heat (preferably some map gas) Once the area is cherry red, use a hammer & tap this thing a little & try to twist it with some locking pliers. Once you brake it free, do have u have to do to wiggle it out of there. Once it's out you will find that it's coroded & possibly rust build up on it, clean it up with a wire wheel (possibly using a bench grinder) Then coat it with anti-seize & re-install. Best of luck :thumbup: |
easier just finding a used caliper bracket whea the pins arent seized..
Originally Posted by mini-me civic
(Post 3712824)
