perch setting on koni yellows
Old Oct 15, 2002 | 03:07 PM
avijiggybear's Avatar
avijiggybear
Default perch setting on koni yellows
hey whats up, i was wondering on how to change the perch settings on my yellows, has anyone done it, if so please throw me some info, thx in advance
Old Oct 15, 2002 | 03:09 PM
cyman83's Avatar
cyman83
bo knows
Old Oct 15, 2002 | 03:35 PM
agent87's Avatar
agent87
Need zzzzz's
You can take a flathead screwdriver and push on one end in the direction you want to move it (up or down). Then work the rest of the clip in that direction. You probably need to relieve pressure on the perch. Not an issue with sleeve type coilovers but might be with lowering springs. It depends on the brand.
Old Oct 15, 2002 | 05:31 PM
avijiggybear
so all i have to do is take off my tire, i don't have to disassemble the strut assembly or anything right, btw i have goldline 1.5" lowering springs
Old Oct 15, 2002 | 06:38 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
If you have enough play in your spring when the car is jacked up then you don't have to take the struts out of the car.
I use the spring clip plyers...
Like $4 at Sears, that way you don't jack up the paint.
Old Oct 15, 2002 | 08:21 PM
SW20 MR2's Avatar
SW20 MR2
I would recommend taking apart each shock assembly.
Old Oct 16, 2002 | 05:01 PM
cyman83's Avatar
cyman83
no one else knows?
