Door swap wiring harness
Old Sep 17, 2007 | 02:15 PM
Rebelwork's Avatar
Rebelwork
senile
Default Door swap wiring harness
Getting ready to swap some doors on a 95 Civ but not clear on the disconnect at the door. Manual not much help either. Is there a push clip,etc on the door itself to disconnect?....Jack
Old Sep 19, 2007 | 04:21 PM
m735is's Avatar
m735is
If I remember correctly, look under the rubber cover and there should be a slide clip to pull out, then unplug the harness. You may have to have the panel off to reinstall the plug. Clean and treat those connections before you put it back together if you live in an oxidation area. It doesn't take much crap in there to ruin the tiny pins.
Old Sep 20, 2007 | 10:35 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
pull the rubber boot back, squeese the clip, and pull.
Old Oct 14, 2007 | 05:34 PM
slintegra's Avatar
slintegra
i just replaced doors on my 95 civic coupe and those wires are probably just speaker wire one should be green and red and the other orange and black unless of course u have automatic windows and what not but if its manual... just cut the wires and rewire them, not too hard.
