Whining???
Old Aug 14, 2007 | 10:09 AM
adva7328's Avatar
adva7328
BOOST PROJECT 99
Default Whining???
I have a 99 EX and when i am in park and turn my steering wheel from right to left it is really loud whining then when i turn. I am thinking I am just low on power steering fluid but I am not leaking any fluid. If it isnt that what do you think it could be. Thanks for all the responses in advance.
Old Aug 14, 2007 | 11:07 AM
dieneverknowing's Avatar
dieneverknowing
Is it more like a whine/groan or a whine/belt squeal? Either way I'd go ahead and check the fluid.
But if it's more of a whine/groan I would guess your pump is going out. If it's more of a whine/squeal I would guess the belt needs tightening or replacing.
All guesses/ideas, but hopefully it might start you in the right direction. :10q: ..Hopefully
Old Aug 14, 2007 | 11:59 AM
adva7328's Avatar
adva7328
BOOST PROJECT 99
def a whine groan that is kinda what i was thinking so i am goin to add fluid if it doesnt go away i am going to just get another pump because it is def not a belt squel
Old Aug 14, 2007 | 12:21 PM
dieneverknowing
Well good luck. Hopefully just topping it off will solve the problem. I'm not sure how much longer a ps pump will go once it begins to make noise.
Old Aug 14, 2007 | 09:17 PM
A-series's Avatar
A-series
v-card member alpha
A very long time in some cases but I'm speaking from non-Honda experience.
If it's low on fluid that will be the likely cause - it should be at the top or 2nd line marked on the reservoir, not above - and if it is leaking, keep it topped up so the pump lasts as long as possible.
If for some reason you aren't using Honda PS fluid, you should be as not only will the pump not work as well with anything else but it will leak if you don't use the Honda stuff.
Just to be clear, when you say it makes the groaning/whining noise (not belt squeel) does it do it all the time as you're turning the wheel or only once you've turned the wheel quite a ways in one direction - nearing the "lock" to the left or right?
It's normal for most, if not all, PS pumps to make some noise when you turn the wheel to the left or right and near or reach lock (as far as it will go).
