Speedo, hazards, blinkers NOT WORKING! HLEP!
Old Aug 3, 2007 | 03:52 AM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
Default Speedo, hazards, blinkers NOT WORKING! HLEP!
I have a 1992 civic hatchback I woke up this morning an the entire gauge cluster didnt work as well as the direction lights, reverse lights and the clock? Any ideas, I checked the fuses both under the dash and in the bay, none were blown. Could it be a relay? If so which one?
Old Aug 3, 2007 | 07:29 PM
jdmeg6hatchy
i
anyone?
could it be a relay?
Old Aug 3, 2007 | 08:01 PM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
yeah definitely sounds like a fuse....check up under your dash.....search around and I am sure you can find a diagram I don't remember which fuses to check
Old Aug 3, 2007 | 08:34 PM
jdmeg6hatchy
i
yeah, ive looked at like every fuse! could it be a relay?
Old Aug 4, 2007 | 07:01 AM
jdmeg6hatchy
i
I think its the Flasher relay, where is that located?
Old Aug 4, 2007 | 07:16 AM
vietnamese_boi's Avatar
vietnamese_boi
double check the fuse again, i had same problem and it was a blown fuse under the dash.
Old Aug 4, 2007 | 07:31 AM
jdmeg6hatchy
i
k
Old Aug 4, 2007 | 08:04 AM
jdmeg6hatchy
i
checked all the fuses. Still couldn't find it. Is there a flasher/hazzard relay??
Old Aug 4, 2007 | 08:33 AM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
I really doubt its your flasher relay.....but replace it and see what happens
did you check EVERY fuse under the dash?...maybe you are overlooking a couple
Old Aug 4, 2007 | 08:51 AM
jdmeg6hatchy
i
I checked every fuse, is there a specific one I should check?
where is the flasher relay, what does it look like?
