Primary O2 sensor help
Old Jul 5, 2007 | 06:28 AM
marc_s's Avatar
marc_s
Default Primary O2 sensor help
Hey, so my cel went for the primary O2 sensor on my 98 Civic Si. My buddy replaced the sensor for me and the light is showing the same code again. Any ideas what else to do or has anyone had a similar problem?
Old Jul 5, 2007 | 06:49 PM
Fuse's Avatar
Fuse
What code exactly (example p1234) there is a o2 heater system and an o2 signal system. If you get me the code I will try to help.
Check connectors and make shure you have an o2 senser and not a A/F senser thy are different.
Old Jul 7, 2007 | 10:34 PM
flappy188's Avatar
flappy188
O.G. SON!
98 civic si? thought they only made them in 99-00?
you might need to reset the ecu.
Old Jul 8, 2007 | 02:07 AM
A-series's Avatar
A-series
v-card member alpha
Yeah, I was gonna suggest that.
Either disconnect the neg. battery cable or remove the ECU fuse for a few minutes - that way you can be sure the code was cleared.
Old Jul 11, 2007 | 07:25 AM
marc_s's Avatar
marc_s
I've disconnected the battery and have also taken the fuse out. The comes on every couple days giving the same code. Honda has told me that I have to use a Honda sensor and I wanted to see if they were f**king with me. Any other suggestions would be great.
Also, Canada has 98 si's, I think the equivalent in the states is the EX
Old Jul 11, 2007 | 08:19 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
It wouldn't be the first time I've seen a Honda kick back a non-Honda sensor.
Old Jul 12, 2007 | 09:15 AM
marc_s's Avatar
marc_s
Thanks a lot
