Any tips to routing AMP wires from deck to trunk?
Old May 16, 2007 | 11:58 AM
thewalrusking's Avatar
thewalrusking
Default Any tips to routing AMP wires from deck to trunk?
Im not happy with the layout and ease of use on my 2000 civic, my 1990 accord was much easier. I would have paid for the installs if i new the trouble. Is there away to easily and somewhat neatly to route the rca cable and power line from batt/deck into the trunk? I find the trim is very hard to squeeze open, especially the thickness for the two wires. I am planning in going under the shifter then between the 2 back seats through the middle, but that might cause people to kick at the wires and rip them out. Any ideas?"
Old May 16, 2007 | 07:01 PM
3lo's Avatar
3lo
i routed my rca cable in the middle by the shifter more to the passenger side, just take out the passenger seat take out the side panels and push the cable in, after you put back the carpet you can hardly feel it;
my gauge 4 power wire and led on wire i routed under the side panels, very easy, its not in any way. better route signal and power wire different way so it doesnt effect sound quality. hope it helps.
Old May 17, 2007 | 01:11 PM
remy's Avatar
remy
Originally Posted by 3lo
i routed my rca cable in the middle by the shifter more to the passenger side!!
double up on that one!! I did the same thing and you will not even see it!!
with a couple of hours of free time you should be able to route the cables from front to back!!
Old May 17, 2007 | 02:37 PM
Civic2Scooby's Avatar
Civic2Scooby
I pulled my driver side seat and my back seat. pulled up the door kick trim for better access and fed it right down the middle. I put the RCA's further to the passanger side and the power wire from the battery further to the driver's side. You DO NOT want to run them next to each other or you risk your RCA's picking up noise from the power wire.
Old May 20, 2007 | 11:21 AM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
my rca's run down the drivers-side, my power runs down the passenger side.
take your seats out to do it. its easier to do than it sounds.
Old May 20, 2007 | 06:22 PM
Outxider's Avatar
Outxider
X-Motoring
:werd: i ran mine the same way. with the seats out, its really easy.
Old May 22, 2007 | 02:06 AM
cj_140's Avatar
cj_140
seats out is indeed the easiest way to go.
Old May 26, 2007 | 03:46 PM
Civic07's Avatar
Civic07
Unique VizionZ
hey man this might help ive got a 98 civic and it was fairly easy for me to run my power wire and rca cables I just ran my power cable from the battery towards the drivers side there should be a large hole in the firewall that no wires are through (or there was one on mine anyway) and pull that plug out run the wire and then zip tied it on the other side in the floor board and then unscrewed my center console ran the wires through both rca and power and then were the console stops I ran the wire underneath the carpet and under the seat to the trunk It looks clean and was fairly easy to do!!!!!
Old May 28, 2007 | 03:16 PM
loprofilefl's Avatar
loprofilefl
N/A noob
do it right.
seats out, wires run, seats back in in 45 mins.
