What ECU do i have?
Old May 6, 2007 | 08:49 AM
awais_uk's Avatar
awais_uk
Default What ECU do i have?
Hi, was wondering if anybody knew what ECU my cars got.
Its a 1997 Civic 1.6iSR (not SiR) with a D16y8 engine.
Saves me stripping off the seat to get a look at it.
Im after the P number and OBD version, would be a massive help if anyone knows it.
Thanks alot.
Old May 6, 2007 | 09:08 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Should be a P2P, I had a 97 Civic EX with a D16Y8 and I have the ECU from it and it says P2P.
Old May 6, 2007 | 09:25 AM
awais_uk's Avatar
awais_uk
Right, i've lookd it up and this in an OBD-II ecu, so for this to work with a
B16a2 all i would need is a conversion harness right? or would i have to replace the ecu itself AND get a harness?
Thanks again.
Old May 6, 2007 | 09:29 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
If the engine is OBD2 with an OBD2 harness you wouldn't need a conversion harness. If the engine is OBD1 you would need an OBD2 to OBD1 conversion harness if they even make those. If not then you would need to get another ECU.
Old May 6, 2007 | 11:03 AM
Snoopy's Avatar
Snoopy
been there done that
you need an ecu to match the engine
Old May 6, 2007 | 12:15 PM
awais_uk's Avatar
awais_uk
the engine is a b16a2 from a
B16A2 1.6 16V DOHC VTEC PGM-FI 1595 160hp@7600rpm 111tq@7000rpm '99-'00 Civic Si (USA) >
how would i find out what OBD version this is?
Thanks.
Old May 6, 2007 | 12:28 PM
Snoopy's Avatar
Snoopy
it's obd2a if it's from a 99-00 civic
Old May 6, 2007 | 01:27 PM
awais_uk's Avatar
awais_uk
ok, finally im gettin somehwere, you guys are legends man.
So i shouldn't need to change my ecu? I cant see how thats possible if i have a much less power engine
but hey if it works why not?
It will work wont it?
Old May 6, 2007 | 01:29 PM
Snoopy's Avatar
Snoopy
you cannot use your current ecu with a b16. you need the ecu that comes with that engine.
Old May 6, 2007 | 01:43 PM
awais_uk's Avatar
awais_uk
oh....... ok. And im guessin im gonna need the wiring loom that came with the engine too? or a conversion harness?
