vss wtf! i have no clue what to do now
Old Mar 26, 2007 | 05:58 PM
civiclxb16a's Avatar
civiclxb16a
Default vss wtf! i have no clue what to do now
well along with everything that has gone wrong with my civic this week i went to get my wheel alignment and of course i need a new tie rod, so i was on my way home and my speedo was jumping around like crazy then it just turned off. about 1 minute later my CEL turns on. i get home and i say maybe my vss went bad. i pulled out one of the extra ones i had laying around and i put it in took it for a test run same thing. tried the thrid one same thing, my buddy came over and we took his out and put it in mine same thing. so what we did was pulled out the sensor and spun it by hand nothing. so we started playing around with the plug while spinning the sensor and the speedo would jump once in a while. could it be my plug went bad on me?
Old Mar 27, 2007 | 03:19 AM
m735is's Avatar
m735is
The wires could have broken inside/at the the plug (corrosion?). Or you have a bad ground-clean and tighten all of those inside the engine bay. If that doesn't fix, try another cluster??
Any other electrical things going funky or just the speedo?
Old Mar 27, 2007 | 04:07 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
most likely its the plug or the wires, the vss grounds at the same point as several other sensors so if the ground went bad youd have more than just a vss problem.
Old Mar 27, 2007 | 05:00 AM
raiden571's Avatar
raiden571
turning u inside out
i would def. check your wires and do continuity and ohms test on it. i am pretty sure haynes manuals have the ohms for it. and if it is the plug, go to a junkyard with a pair of wire cutters problem solved.
Old Mar 27, 2007 | 06:02 PM
civiclxb16a
crazy question but i have an old wiring harness clips from the ecu can i use those pins to pin my vss?
Old Apr 9, 2007 | 12:35 PM
civiclxb16a
i changed the clip today and took it for a run and sure enough it worked! thanks guys
Old Jun 2, 2007 | 05:22 PM
Bifwat's Avatar
Bifwat
Bifwat
Default Clips, What Clips
Hey when you say "clips" are you talking about the plug in connector to the VSS? I'm going thru the same thing. Bought a VSS, no go. Borrowed a VSS from same year civic, same result.
Old Jun 3, 2007 | 05:49 PM
civiclxb16a
yeah i did the same thing i replaced the clip with the three leads on it
