I need to remove my rear brake drum cover so i can get at the hub and bearing to replace them but i dont have the bolts to get it out that way i need help and fast so i can get to work at 5:00PM thanks to any body that can!!!
Well, it's a little late, but you can pound them a little with a hammer to break all the crud loose and then try to pull it off. Just remember to release the e-brake before you do this.
Spray some penetrating oil like pb blaster on center of the hub and let set. Then bang like hell with a sledge hammer. Bang it and rotate it so you don't warp them. You can use two bolts and thread them into those threaded holes to pop it off. Yeah, it's a bitch.
