need help with wheel studs
Old Nov 25, 2006 | 10:29 PM
darkskyracing's Avatar
darkskyracing
Default need help with wheel studs
does anyone know how to get the wheel studs out of a 98 civic coupe and put the new ones that i have in. i already have the studs and i have the rotor off but i need to know how to get the hub off. any help greatly appreciated. thanks
Old Nov 26, 2006 | 04:02 AM
teg92's Avatar
teg92
WHAT OK YEAH!
i think you have to remove the wheel bearing to get the studs out
Old Nov 26, 2006 | 01:02 PM
Fuse's Avatar
Fuse
You might be able to sneak it by.Usually you have to remove the hub and you would need a pres for that.
Old Nov 26, 2006 | 01:19 PM
civicburner's Avatar
civicburner
I've taken wheel studs out before by smacking them out with a hammer. But that was on the rear. You'll probably screw up your alignment doing it on the front.
Old Nov 26, 2006 | 04:30 PM
G-M-W's Avatar
G-M-W
i think they need to be pressed out....i just took it to the gas station at the corner...was like $12
Old Nov 28, 2006 | 07:00 AM
EGROM960's Avatar
EGROM960
EG6...
im better sure you just bang them out with a hammer on the side which sticks out....thats howi took mine out...no damge at all but see i have a 92 civic...i dont no if that helped.
