93' civic projector light problem
Old Oct 31, 2006 | 05:20 PM
d1_driftking's Avatar
d1_driftking
drifting my way to hell
Default 93' civic projector light problem
ok as the title says im having trouble with my projector lights.
the one the passanger side the halo's are not working anymore i've checked them on another car and they worked but when i connected them in my car they dont im sure its a wiring problem. i checked the wiring on the other car and its the same on both cars.
now the second issue is on the driver side the low beams dont work.
can anybody help?
maybe direct me in the direction were i can find a walkthrough or a DIY guide on the wiring?
Old Oct 31, 2006 | 06:34 PM
d1_driftking
anybody?
Old Oct 31, 2006 | 06:52 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
fuses..ground...wiring harness/wires arent connected well
blown bulb on the low beam.
:dunno:
Old Oct 31, 2006 | 06:59 PM
d1_driftking
i checked my fuses they are all good i even changed them to be 100% sure im thinking its something with the wiring.
if anybody has a walkthrough on instaling them i would really appriciate it if they could post it.
Old Nov 1, 2006 | 02:50 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
I had those things on my Civic when I first got it 4 years ago. Halo's went dim on passenger side. This is what I did, but instead of doing step 3 I sold them to a dumbass ricer for the price I paid for them :rofl:
Easy fix, only3 steps.
1. Remove projector halo jdm spoon mugen headlight assemblies
2. Replace with stock headlight and corner light assemblies
3. Burn projector halo yada yada.
Old Nov 1, 2006 | 05:03 PM
Fuse's Avatar
Fuse
hi lets check all the fuses first then see if you have 12v to the hight and low beam
Old Nov 1, 2006 | 05:13 PM
Fuse's Avatar
Fuse
let me try again hear is a better pick.so see if you have 12v at red/wht and red/blu with the rite low or hight beam on. let me know your ground could be loose or broken if you see 12v at each wire but it doesn't turn on or you terminals are not connecting
Old Nov 2, 2006 | 05:14 AM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Did they ever work, or is this ur first install on them?
Old Nov 2, 2006 | 09:48 AM
d1_driftking
they worked when i first installed them i fixed them already thanks all for the help
there was a problem with the plug it wasnt making full contact so i replaced it and on the love beam there was a cable that had been cut off maybe i did it by accident last time i removed them. everything is fix now so thanks you all.
Old Nov 3, 2006 | 03:50 PM
Fuse's Avatar
Fuse
Default hi
i would tap into the red/wht on the head light switch so your lights work with the light switch one wire to each light.i made a diy on wiring just search wiring 101 use the soldering procedure or the heat shrink but connector procedure(if you do don't use a shitty crimper use one that looks like mine it will give you a the best crimp).
