95si tranny fits 98ex motor, axle and starter?
Old Oct 1, 2002 | 06:53 AM
vizeta's Avatar
vizeta
Default 95si tranny fits 98ex motor, axle and starter?
Does 95 SI (D16Z) 5sp tranny fit 98 EX (D16Y8)? Can I apply my current axle and starter to D16Z tranny? I'm going to swap my auto to manual and hope I can use my friend's D16Z SI tranny. Thanks.
Old Oct 1, 2002 | 07:13 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
It should fit.
Autocross Help Page
Old Oct 1, 2002 | 07:25 AM
vizeta's Avatar
vizeta
Thx CivicSiRacer, but what about the tranny mount? can I use the mount for 96+ manual?
Old Oct 1, 2002 | 10:03 AM
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
Everything fits except the throwout bearing was different when we did it. We made it fit though.
Old Oct 1, 2002 | 12:45 PM
vizeta's Avatar
vizeta
Thx alot. throwout bearing? where is that located? Thx for your input again.
Old Oct 1, 2002 | 01:01 PM
SpeedRacerEX-R
It goes inside the tranny on the shift fork. Just order the throw out bearing for that tranny.
Old Oct 1, 2002 | 01:49 PM
MNY2BRN's Avatar
MNY2BRN
I hate you too
while on the subject, is it possible to replace a b16a clutch with a b16a2 clutch and tranny? I'm thinking if I replace the complete clutch assembly and flywheel, the hydro clutch will work on my 97 ex. Any thoughts would be helpful.
P.S. If anyone is selling a b series hydro tranny, I am very interested. thanks
Old Oct 1, 2002 | 04:17 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
If the flywheel bolts up to the crank, then you can do it. Not sure if it would be the same flywheel, bue like I said, swap out the flywheel and you should have no problems (if it's possible). And the hydraulic lines that are on the ex might need to be bent to work. Not a problem with a pipe bender.
Old Oct 2, 2002 | 02:02 AM
SpeedRacerEX-R
You aren't talking about putting a B16 tranny on your ex are you? If you are, the answer is no.
Old Oct 2, 2002 | 04:35 AM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
I was assuming it was an EX with a swap...
