Damn Ebay Foglights
Old Oct 28, 2006 | 07:29 PM
95LSv's Avatar
95LSv
Banded
Default Damn Ebay Foglights
So I bought some ebay jdm yellow fog lights and besides them being total crap, they didn't even come with instructions. Does anyone have some instructions on how the wire these? And they are not even bright, except from certain angles, is that normal??
I have some like these
PS I wired them w/o instructions and they work except the led in the turn on button is always on
Old Oct 28, 2006 | 10:20 PM
Fuse's Avatar
Fuse
the easy way would be to run strait off the battery (run one hot wire from the battery to a switch then from you switch to the lights then ground the lights any where you see fit.
Old Oct 28, 2006 | 11:46 PM
95LSv's Avatar
95LSv
Banded
I think I may have found the answer. To anyone else who has this prob. I will tap the yellow wires (kinda weird, but the whole setup has one black, one red, and 2 yellow wires), into the parking lights or headlight wire. So the whole fog light systems will only be able to be turned on iff the parking lights or headlights are on. As opposed to now, where I can turn them on independently.
Old Oct 29, 2006 | 04:46 AM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
That's how it is supposed to be (the fog lights coming on, I don't know about the wirining.). Go into any other car and you can only turn on the fogs when you turn on the headlights.
IDK about anyone else, but I have just liked to wire things the way their supposed to be. I used be the person that if their radiator fan didn't work, i would just wire it to a switch and a battery. I like clean stuff done the right way now, so somethin for ya to keep in mind.
Just my .02 cents
Old Oct 29, 2006 | 02:01 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
You actualy want to wire them to your low beams. In some states it's illegal to have them on with the high beams. So they should turn off with high beams but come on with low beams.
Autocross Help Page
Old Oct 29, 2006 | 03:43 PM
95LSv's Avatar
95LSv
Banded
Yep, thats what I did. I tapped into the positive on the low beams. Now when the low beams are on, my foglights can be turned on. But they also have a switch, so they are independent of each other. I can have my lows on w/o having the fogs on.
Also, the fogs aren't really that bright, except in certain angles, is there a way to fix this?
Old Oct 30, 2006 | 11:42 AM
95LSv's Avatar
95LSv
Banded
Are there any different types of bulbs I can use with these foglights to make them brighter?
Old Oct 30, 2006 | 01:33 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Hatch/Coupe: http://www.hondaautomotiveparts.com/.../16603_01.html
Sedan: http://www.hondaautomotiveparts.com/.../16607_01.html
