97 Civic MES Connector
Old Oct 25, 2006 | 09:23 AM
dreyerwolf's Avatar
dreyerwolf
Default 97 Civic MES Connector
Ok, had airbags replaced. They didn't reset SRS light (it wasn't a honda dealer that did the work, they were the ones my insureance wanted). Figured I do it myself and if that didn't work, then I'd take the time off, make them check it out.
here's the thing. Found the MES connector. Dang thing will not let go of the fuse pannel. won't come out of the dummy holster. didn't seem to be any clips or releases. I'm afraid I'm going to tear the darn fuse system out of the dash, or bust it off.
Any ideas.
dreyerwolf@yahoo.com
Old Oct 25, 2006 | 07:34 PM
Fuse's Avatar
Fuse
their are 2 yellow connectors on some models one has a clip you push down comes out easy thats the one you want their is another that is bigger and you have to pull on the box that is the rong one don't short that one.there is info in the diy on this site.
Old Oct 26, 2006 | 05:02 AM
dreyerwolf's Avatar
dreyerwolf
there seems to be only one on my model. It's even labeled on the fuse "directory" as SRS. I'm assuming since it's big and yellow and labeled, that it's the one I'm looking for.
Old Oct 26, 2006 | 08:20 AM
Fuse's Avatar
Fuse
its on the drivers side fuse box its not that big just a 2 pin and a push down tab shot it and turn the key on count the srs blinks.
Old Oct 26, 2006 | 11:04 PM
stereo's Avatar
stereo
you need to replace the SRS computer if the bags deployed it will not reset also if the plug you are refering to in next to the 2 fuses with yellow covers it's NOT the MES connector and will mess it up takeing unplugging it as it's the power plug to the SRS the clip is interlocked to prevent someone from unplugging it. the MES is next to it ans looks like the SCS plug but yellow.
Old Oct 31, 2006 | 08:20 AM
dreyerwolf's Avatar
dreyerwolf
They weren't deployed, they got stolen. Not sure if it results in the same situation. I just though I'd try and reset it before having to take time off from work and take it back to the shop that installed them. I don't have much faith in them at this point.
Old Oct 31, 2006 | 08:42 AM
dreyerwolf's Avatar
dreyerwolf
you were right, there are 2 of them (yellow). I was trying to pull the lower (and bigger one). No way that one is coming out. There is one hiding further up on the board behind a whole cluster of wires. looks like it has the easy clip you described. As I look at it, it has 3 wires running to the connection.
Would someone like to clarify if that's the one I want before I disconnect it?
thanks.
Old Oct 31, 2006 | 10:36 AM
dreyerwolf's Avatar
dreyerwolf
Default Picture will make this easier
Ok. I took a pic of what I see. Funny, there looks like WAY more room than there is. I can barely get my hand up in here.
So, (A) is the one I couldn't get free from the fuse board. (B) come off with an easy clip, but it has 3 wires.
So which do I want?
Old Oct 31, 2006 | 04:20 PM
Fuse's Avatar
Fuse
a 2 wire
Old Oct 31, 2006 | 04:33 PM
Fuse's Avatar
Fuse
hears what i found on the driver side for a 97 civic doesn't look rite maybe passenger side(2 wire)
