1994 Civic AXEL to transaxel
Old Oct 13, 2006 | 05:09 PM
sevenfive's Avatar
sevenfive
Default 1994 Civic AXEL to transaxel
Just replaced a lower ball joint, That when it popped it pulled the avel from the trans, when replacing I did not know if anything goes back into the transaxel with the axel. Reason I ask is there was a bearing the was on the floor covered in grease like it came from the trans/axle joint, but I am unsure where it goies to. It does not fit over the axle, and there was not a spot that it fit snuggly into the transaxel. Bearing is about 1'1/2. Flat one side on other there is a slight ridge that borders the center hole. In center there is a ring that is movable 360 degrees. My thoughts is it could be a spacer, but that is only a guess.
Old Oct 13, 2006 | 05:56 PM
Running925's Avatar
Running925
Your Powder Coater
this sounds Extreamly bad.. please post pix so we can help u out.
your positive that this bearing came out the axle hole?
Old Oct 13, 2006 | 06:01 PM
sevenfive's Avatar
sevenfive
no. that's the problem. but it was covered in axle grease. we're trying to get pictures.
Old Oct 13, 2006 | 06:07 PM
Running925's Avatar
Running925
Your Powder Coater
it's very unlikley that anything came out of the axle hole on the tranny. The only thing that i could imagine you saying you found would be the circle clip that is probably still attached to the end of the axle that was in the tranny.
To be totaly honest with you, i can't think of one bearing that is in your tranny that is even small enough to fit out the axle hole.
once you get some pix posted, i'll be able to give you a better explaination, i'm gonna go back out to the garage & finish some body work, i'll check back later.
Old Oct 13, 2006 | 06:29 PM
sevenfive's Avatar
sevenfive
Default pictures of bearing
pics of bearing
File Type: jpg
File Type: jpg
Old Oct 13, 2006 | 08:19 PM
Running925's Avatar
Running925
Your Powder Coater
and how bout a pic of the side of the tranny that you pulled the axle from.
Old Oct 14, 2006 | 05:26 AM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
Those bearings go on he end of the cv joint inside the boot. There are 3 of them. Pull the axle off and get go get a new one at the auto parts store.
Old Oct 14, 2006 | 05:35 AM
teg92's Avatar
teg92
WHAT OK YEAH!
I agree your going to need a new axel
