Header???
Old Sep 19, 2006 | 02:54 PM
hawj920's Avatar
hawj920
Default Header???
Would a B18B (LS) header fit a B16? I am thinking about buying a used DC sports header for my car... Thanks
Old Sep 19, 2006 | 03:04 PM
Snoopy's Avatar
Snoopy
been there done that
it will most likely bolt up, but would hang lower than a header designed for a b16.
Old Sep 19, 2006 | 09:48 PM
95LSv's Avatar
95LSv
Banded
Yep it will bolt up. I did it one my b16, but I don't know about the hanging lower part, it was an oem header and I never really checked, so snoopy is probably right. But either way it works.
Old Sep 19, 2006 | 10:20 PM
Civic2Scooby's Avatar
Civic2Scooby
:stupid: and not most likely, it WILL bolt up perfectly, though you will likely have to lengthen your o2 wire.
the deck height on the b18 is higher...so yes the header hangs down a tad...nothing noticeable.
Old Sep 20, 2006 | 07:07 AM
EricsLSHonda's Avatar
EricsLSHonda
Default brake lights stuck on help me please!!!!
ok well ive had my car for a bout a year its a 1994honda civic with a 2000 1.8 ls motor didi a bunch of work and probably 6 months ago i had no power at all. i replaces the psoitive wire going from the battery to the fuse box. butttttt......there are two wires that go into the box. in order for me to get power and my car to start i screwed both into the same one cause it was like the other one had no power. now idk if thats causing my problem but my brake lights are stuck on when the car is on. when its off its fine they are only on when the car is on and when i drive it looks like im riding the brake the whole way. can neone help cause this is cauing power porblems and my battery to go dead and when i turn my radio on if the key is in the on position even for a second the battery will go dead. i tried taking fuses out and the lights wont go off please neone help!!!!
Old Sep 20, 2006 | 03:22 PM
97_hatch's Avatar
97_hatch
And why is this in here??
