trouble with engine code..
Hey
i recently finished my mini me d15b7 bottom and d16z top...now im throwing a code..however the engine light only turns on when the engine is running, and so i cant pull the code becaise as soon as i turn the car off the engine light turns off and i cant pull the code while its running. any help?? |
double check your wiring... i think rywire has some instructions...
U should be able to pull the code with KOEO (Key on Engine Off) just by shorting the 2p connector on the passenger side. If it set the code it will be stored in the memory, unless u have pulled the battery, then u have to drive the car till the light comes on.
