need help asap...starting issues.
Old Aug 18, 2006 | 09:50 AM
a_integra_87's Avatar
a_integra_87
Traction, WTF is that?
Default need help asap...starting issues.
Alright, any and all help is needed. I have to have this car running, tomorrow i leave for college at 6am and need a car.
Long story short i was wiring up a fuel killswitch, started the car fine, killswitch worked. Tried to start the car again, fuel pump kicked on, but once i went to hit the starter everything died.
Pulled EVERY fuse in the interior fuse box and replaced them, swapped all relays in the interior fuse box with my sisters HX. Pulled every fuse in the exterior fuse box and replaced them and swapped all relays out there i could find and i still have nothing.
The car has no power at all in any part of the car. The little key beep used to work, then 30min ago that stopped too.
BUT
Now if you let the car sit about 10min all power will come back on. The fuel pump will prime, but once you hit the starter everything shuts off for another 10min.
Need help really bad here.
EDIT: i also totally took the killswitch back off and now its how the car was OEM.
Old Aug 18, 2006 | 09:52 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Main Fuel Relay
Old Aug 18, 2006 | 10:06 AM
a_integra_87
wheres that?
