Main Relay Experts HELP!!!
Old Aug 13, 2006 | 06:11 PM
Midori's Avatar
Midori
Default Main Relay Experts HELP!!!
Ok, my 92 EG has had the typical main relay problem in the past and I solved it in the usual manner by resoldering.
Well the other night it pulled a typical "main relay problem" turn the ignition and no "click" and no hummm from the fuel pump. Car cranks fine. OK resolder again and still nothing. Jump terminal 1 and 7 and the pump primes so that's not the problem. Thinking it's still the main relay I verify if it's good in a friends car and sure enough it is.
Now my question...what would cause this problem if the Main relay is good and fuel pump is good.
Old Aug 13, 2006 | 09:15 PM
stereo's Avatar
stereo
bad ECU ? if the CE is turning off like it should if not check power & ground.
Old Aug 14, 2006 | 03:36 AM
m735is's Avatar
m735is
Swap your friends distributor into your car and try it.
Old Aug 14, 2006 | 12:04 PM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Was it cold out when u put it in ur friends car!? Was it not hot as nuts out!?
How bout getting a new main relay, put his in ur car and try it.
Old Aug 16, 2006 | 12:41 AM
Midori's Avatar
Midori
Know all too well about cold solders on Main Relays....this time it ended up being a fried ECU(Stereo Nailed It!) Thanks guys!
Old Aug 16, 2006 | 04:14 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Yeah I was getting frustrated with my main relay during this past summer (and only had the car for 2 months). Finally gave in and got a new one and just heard about soldering it. So now I have a back up just in case.
Autocross Help Page
Old Aug 21, 2006 | 08:14 PM
GaryC17's Avatar
GaryC17
Is the hummm sound when you turn the key to on suppose to be very loud? Mine is loud occasionally but at times it sounds like it does not prime(but there is click from the relay). Could the alarm module be faulty since there is some wiring to the fuel pump via it?
Kaspin
Do It Yourself
21
Feb 9, 2010 08:46 PM
IrishBrewer
9
Nov 9, 2007 02:16 PM
nonbox
Engine Swaps, Tech & Tuning
Jan 29, 2006 03:41 PM
phil300z
CRX & Pre 92 Civic
35
Oct 27, 2005 05:08 AM
jhutchins
CRX & Pre 92 Civic
3
Jul 16, 2005 12:45 PM
