help engine light
Old Jul 25, 2006 | 06:55 AM
heinousmule's Avatar
heinousmule
skeet skeet
Default help engine light
ii have four engine codes
3, 41, 6 and 17
the car back fires, the check engine light is on, and when u try starting the car it starts funny, it doesnt start on first crank other then that ive been driving it any suggestions?
you think it might be a gasket leak or something cos when i drive i can smell a little bit of smoke and when u downshift u can smelll gas
i'll need jesus help on this one lol
Old Jul 25, 2006 | 07:21 AM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
What year of car? Swap?
Code 3 is Map Sensor(defective circuit, or unplugged, defective sensor)
Code 6 is ECT Sensor
Code 17 is VSS Vehicle speed Sensor.
Code 41 is Primary Oxygen Sensor - Heater
circuit malfunction
The O2 sensor and the MAP sensor would explain the startup issues. But why wouyld you say a gasket leak? If your cel is on then fix those problems first.
Old Jul 25, 2006 | 07:34 AM
heinousmule
skeet skeet
would a bad o2 sensor cos u to smell gas when ur motor is running?
Old Jul 25, 2006 | 07:35 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Both the map sensor and o2 sensor will cause you to run rich
Old Jul 25, 2006 | 01:40 PM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
I would do the map and the O2 sensor together. If you do one now and then do the other a couple weeks later it might cuse damage to the new part.
