Car died, no turnover & clicking from fusebox
Old Jul 17, 2006 | 01:03 AM
mini-me civic's Avatar
mini-me civic
its ur main relay dude.. u can try testing ur starter to see if ur ignition switch is to blame by connecting a line straight to the battery to the starter.. if it cranks starter is all gee.. but i thhink its the main relay..
Old Jul 17, 2006 | 12:06 PM
fastback's Avatar
fastback
If it clicked before and had this issue off and on, it is most likely the starter. No, you cannot replace the solenoid only, you have to replace the starter. Be prepared for sticker shock, as starters are not cheap, especially OEM ones. I'd have it checked, because there are other things it could be inside the distributor - ignitor or coil, both of which are also not cheap. I know, I have this problem with one of my Tegs right now.
Is it a stick? Push start it if it is.
You can tell if a fuse is blown just by looking at it...if the starter relay is clicking, it probably isn't the relay.
Old Jul 17, 2006 | 02:07 PM
Luv2reV's Avatar
Luv2reV
Thank you so much guys!!It was the batt!! I did not let it charge long enuf , once I did it started but died when I got home. Changed it today & all good!Cant believe it was that easy. God I love Honda's!!
