Checking compression
Old Jul 14, 2006 | 12:42 PM
abarone300's Avatar
abarone300
Default Checking compression
Hi guys, wanted to ask if I would be able to check the compression with both of my cams off. I got a 1.6 LT dual oh VTEC/ '95 Del Sol
I'm removing the head to check if any of my valves are bent after the timing belt broke.
I did try to install a new belt, and the motor did run afterwords, but not too good though...
Had to advance the timing all the way, to be able to drive the car. I suspect I have low compression because of bent valves.
Also, do you guys know a way to get to the lower intake manifold retaing nuts (can't even get my hand in there to check!) Thanks
Aldo
Old Jul 14, 2006 | 12:44 PM
abarone300's Avatar
abarone300
Default Also...
With both camshafts out, aren't all four valves on all combustion chambers closed?
If I where to remove the all four spark plugs, and alternatively hook up the compression gauge to each chamber, shouldn't I be able to measure compression when the piston is on TDC? Thanks
Aldo
Old Jul 14, 2006 | 12:46 PM
Running925's Avatar
Running925
Your Powder Coater
if u can turn it over, yea it would work.. (manually, apparently)
Old Jul 14, 2006 | 07:45 PM
abarone300's Avatar
abarone300
Default Thanks Tony, I new you'd see it my way...
Just wanted to see what kind of compression I have, before I take the head out, mh...mh... I mean off.
Do the valves have guides? is there a good chance that the bent valves have bad guides also? Some time ago the timing belt broke on my Alfa Romeo GTV, and that's exactly what happened: three bent valves and their respective guides had to be replaced! Thanks
