Need help with steering rack.
Old Jun 11, 2006 | 04:55 PM
96scgsrcoupe's Avatar
96scgsrcoupe
Default Need help with steering rack.
Can someone please tell me how to remove the steering rack from an eg coupe. I have removed tierods on driver side(like haynes book says to). I even removed driver axle but I still can not figure out how to get it out. Please help need my car back.
Old Jun 11, 2006 | 05:39 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
There are 4 bolts that hold the steering rack to the rear engine subframe and there is also a universal joint that holds the steering shaft to the rack. If your car has PS, there will also be two lines going to the rack that must be removed.
Old Jun 11, 2006 | 09:33 PM
96scgsrcoupe
I have every thing disconnected. I just cant figure out how to wiggle it out. Is there some trick to it, or do I need to take the rack apart.
Old Jun 12, 2006 | 02:16 PM
96scgsrcoupe
Old Jun 12, 2006 | 05:37 PM
Andy's Avatar
Andy
My bad, I didn't have a motor in the way, if everything is disconnected, I woudl think taking it out the drivers side is going to be easiestl. Just twist and fanagle and it will go.
Old Jun 13, 2006 | 02:10 PM
96scgsrcoupe
Alright I will try it again. I am thinking about pulling the torch out.J/K Hopefully it will come out with ease. Thanks for the replys and help.
Old Jun 16, 2006 | 11:32 AM
Andy's Avatar
Andy
If you cannot find the room to remove it, you can always make some by lowering the rear engine subframe. There are only 4 large bolts that hold it in place. I wouldn't recommmend removing all of them while the engine is still attached, but you could loosen then 1/2 way and probably drop the subframe by an inch or so, might buy you the clearance you need. Good luck.
Old Jun 16, 2006 | 12:03 PM
asheylarry's Avatar
asheylarry
you might remove the alternator to get more wiggleing room. most of them you just have to wrestle out of there.
