Cylinder Head swap help
Old Jun 3, 2006 | 07:57 AM
Antihero657's Avatar
Antihero657
Default Cylinder Head swap help
I have a 97 Honda Civic HX, and i have swaped the Head from the EX after i got it ported and pollished with new valves and springs ect.... i put it in its all on correct( everything at TDC ect. ect), i even followed a few "mini me" swap write ups. But now my car is reading No Compression (0 psi) with my Comp. tester, I kept the HX Cam in there because the EX cam i have with it is baddly worn. I was thinking this could be the problem and was going to swap the cams out today, or that my timing is just off all together, but since i dont wanna buy a timing light i wanted to ask first
Help is much appreacited, i have no car
Old Jun 4, 2006 | 12:24 AM
bambbrose's Avatar
bambbrose
the cam for sure.
the HX cam has one less lobe that the EX one. You could have bent things bolting that down possibly.
I would switch out to the correct cam, adjust the valves, and go from there
Old Jun 10, 2006 | 07:58 AM
Antihero657
Thanks Man it was the cam.... everything is good to took it for a test drive, has deff. power loss for timing so im taking it somewhere and getting it dyno tuned tomorrow
Old Jun 10, 2006 | 09:03 AM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
tuned with what?
Old Jun 10, 2006 | 10:56 AM
eonsx311's Avatar
eonsx311
today is not my birthday.
unless you have either an adjustable cam gear (which is pointless on a sohc) or a stand alone (which is also pointless on a na non modified motor) you just need a timing adjustment which can be done without a dyno. btw are you using an ex ecu?
