97 Civic A/C
Old May 31, 2006 | 04:24 PM
don_quitoxe's Avatar
don_quitoxe
Default 97 Civic A/C
I have a 97 Civic LX 4D, The A/C was working fine since the last 2 years but I had parked it for 3 months in winter without using it and ever since it doesnt work at all. I suspect the gas leaked out but how does one check for a leak without paying a fortune?
Are there any tell tale signs? I can smell some weird gas when I switch it on now and the compressor does kick in......
What is a good price to get it refilled?
Old May 31, 2006 | 10:56 PM
ari_one's Avatar
ari_one
A/C that may have a leak is not the best thing to be playing with. Most shops have a machine that they hook up to your a/c and it will pull all your R134A out and check for a vacuum leak at the same time. The machine can then fill up your a/c. Most places in my area charge about 50-70 for the check and then a per pound charge to fill up. If you don't have a vacuum leak and need other repairs it should cost you in the 80-120 area.
Old Jun 1, 2006 | 07:47 PM
remy's Avatar
remy
you can alwayz buy an a/c recharger kit for like $40 bucks in autozone/strauss auto/pepboys and or the like. give it a try. i mean it doesnt hurt to try...im sure they come with directions as how to do it!
if not just do like he said and take it to a shop and have vacuum run!
Old Jun 1, 2006 | 09:32 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
I just got done replacing the evaporator core and one of my a/c lines under the hood.
a/c ownes south texas heat :woowoo:
Old Jun 2, 2006 | 02:51 PM
remy's Avatar
remy
i went to pepboys to check if my a/c system had a leak and to get it evacuated and recharged because it was not throwing cold air as before!
it cost me $100 bucks!!!
Old Jun 3, 2006 | 02:22 PM
don_quitoxe
Default Estimate
Well I took it to my local Precision Tune AutoCare Centre, they said that it had a condenser that leaked. The estimate given was $355.95 for replacing the part plus the evac/recharge for like 89.99 + 49.99 (per pound of gas)....They did like a pretty quick job with it and they said that they carried out a vaccum test and had some sort of leak detection gun which beeped at leaks.....How reliable is this? Should I go for a second opinion? I mean my car was doing OK until like the winter when it was standing for 3 months......
I think the part itself runs around $100 online and so this estimate is more like a crapestimate......Any Opinions?
Old Jun 4, 2006 | 10:38 AM
remy's Avatar
remy
a condenser cost like a $100 bucks just like u said...i dont know why they are charging $355.
i know for sure that the compressor cost that much,but not the condenser!
u can alwayz ask them the parts that are bad, and double check it with another shop!
and if u can buy the parts yourself, alot of the times u can buy them way cheaper for what they charge you!
