sir2 performance
Old May 31, 2006 | 03:43 PM
honda_civic's Avatar
honda_civic
Default sir2 performance
hi there i have a civic eg sir2. i am lookin to do some performance mods, is the skunk2 intake manifold any good? and what is the best exhaust manifold header for this car? and what other performance mods do u recommend?
Old May 31, 2006 | 04:05 PM
cvchtchbck92's Avatar
cvchtchbck92
Anti-Ebayer
what mods have done already? I wouldn't recommend the intake manifold or a header unless your going with force induction. Your engine is probably already receiving all the air it needs and is not being restrained by the exhaust manifold.
Old Jun 1, 2006 | 06:51 AM
honda_civic
at the moment there is no other mods except full system mongoose exhaust, wat about skunk 2 cams??
Old Jun 1, 2006 | 11:17 AM
cvchtchbck92
Anti-Ebayer
cams are good, but you're not going to get anything impressive on a stock engine. Note: This is from what I read on a previous thread on this forum. I would have quoted, but I'm too lazy to look for it.
Did you end up swapping your engine? I noticed you put up a thread about swapping. How much horsepower and torque are you generating right now? How much do you want to generate? What's your goal?
Old Jun 1, 2006 | 02:03 PM
honda_civic
Default civic engine swap
sorry for the confusion but im thinking of swapping engines for my other car which is civic 1.5l non vtec D15B2 to a D16z6. the car that i am asking for performance mods is my civic sir2 DOHC vtec.
im just wondering what problems there might be in swaping my non vtec engine to a vtec engine. any extra wiring needed? etc.
thanks
Old Jun 1, 2006 | 02:27 PM
fathergoat's Avatar
fathergoat
:3
I think you will need some extra wiring for the vtec solinoid. Seach around you should find an answer. As for mods, the only good mods for an SOHC is turbo or build+turbo. Going N/A on an SOHC won't get you much.
Old Jun 1, 2006 | 04:13 PM
Omniscient's Avatar
Omniscient
warm butter on toast
I believe it's green/yellow wire for the selinoid to A4 and the oil pressure black and blue wire to D6.
Old Jun 1, 2006 | 04:30 PM
honda_civic
Default civic swap
if i do a complete swap and not just a mini me will i still need to convert from dpfi to mpfi and still wire up the vtec. i am going to used the d16z6 original ecu.
thanks
Old Jun 1, 2006 | 06:28 PM
Omniscient's Avatar
Omniscient
thanks
Yes you need convert to multi point injection and still wire the VTEC.
Old Jun 2, 2006 | 02:28 AM
honda_civic
how exactly do i do that,could u direct me to a guide or sumthin.cheers
