which ecu is better?
Old May 27, 2006 | 01:29 AM
mini-me civic's Avatar
mini-me civic
Default which ecu is better?
which ecu is better.. stock... P08 or P28...
Old May 27, 2006 | 03:44 PM
Fkatz's Avatar
Fkatz
p28 cuz u can chip and tune easy
Old May 27, 2006 | 04:54 PM
mini-me civic
i have a 96 civic cx and i with a mini-me.. im planning to covert to a p08 obd1 using a jumper harness.. do i need a obd1 dizzy or will my obd2 be no problem..
Old May 27, 2006 | 08:32 PM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
All you need for that is the jumper harness and p08. The dizzy will be fine. If you change the dizzy to a obd1 then you would have to change your engine harness also.
Old May 28, 2006 | 11:06 PM
mini-me civic
one last question.. the p08 that i have is a JDM ecu.. i was wonderin if it is a plug n play with the obd2a to obd1 jumper harness... ??
Old May 29, 2006 | 07:33 PM
mini-me civic
will a jdm obd1 P08 be a plug and play with a obd2a jumper harness on to my D16y8 mini me?? or will i hvae to rewire sum stuff.. n e onleplz.. help
