Need help with code 22
Old May 23, 2006 | 08:37 PM
mattatuncg's Avatar
mattatuncg
Default Need help with code 22
Today driving around, my CEL came on. I checked it and its throwing a code 22 (VTEC Oil Pressure Switch). Oil was recently changed about 1000 miles ago, and oil level was fine when I checked it. What are some steps I can do to correct this problem? The car is a 94 Civic EX with a d16z6 engine.
Old May 23, 2006 | 11:30 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Take the sensor out and clean it, check your oil level, check for any crap that might be in your oil. Check to make sure there's a complete circuit with a volt meter.
Old May 24, 2006 | 09:17 AM
mattatuncg's Avatar
mattatuncg
Thanks fixed the problem this morning. Turns out the plug was a little dirty. Some brake cleaner to the plugs and a few minutes of drying removed the CEL, and VTEC is back to normal...for now.
Old May 26, 2006 | 02:08 PM
mattatuncg's Avatar
mattatuncg
10 minutes later CEL is back. Checked the code again, this time I get 21 and 22. I guess I'm just gonna try another solenoid.
Old May 27, 2006 | 11:53 AM
mattatuncg's Avatar
mattatuncg
Any more thoughts on this? Now only throwing code 22 again.
Old May 27, 2006 | 12:54 PM
Omniscient's Avatar
Omniscient
Mad oil switch I'm guessing. Check the continuity between the wires with a volt meter.
Old May 27, 2006 | 09:12 PM
mattatuncg's Avatar
mattatuncg
Voltage check came back fine. I have on order another solenoid, so I'm just gonna change the oil again for now. I just bought the car not too long ago. I never bothered to ask if the car was running snythetic. I just drained whatever was in it, then loaded up with 10w-30. CEL didn't happen till about 1200-1500 miles into the change. If this engine HAD a different weight oil, or synthetic, would that cause this problem without a proper engine flush?
Old Jun 1, 2006 | 11:12 AM
mattatuncg's Avatar
mattatuncg
Problem solved with the swap of another solenoid.
