Auto - Manual Conversion
Old Sep 22, 2002 | 09:21 PM
HeavyCivic's Avatar
HeavyCivic
Team HighRev
Default Auto - Manual Conversion
hey guys
im getting ready to do the automatic-to-manual conversion on my civic
just wanted to make sure im not forgetting anything
so far my checklist is:
- manual tranmission (obviously ) picked up a gsr tranny
- pedal assembly (clutch, brake, and gas) still looking
- clutch booster still looking
- slave cylinder still looking
anything else im missing???
Old Sep 24, 2002 | 07:22 AM
HeavyCivic's Avatar
HeavyCivic
Team HighRev
uh huh....
Old Sep 24, 2002 | 07:31 AM
Nelson's Avatar
Nelson
Administrator
Parts included with a swap:
tranny
shift linkage
shifter
slave cylinder
Parts you'll need from a 92-95 Civic 5 speed or 94+ Integra 5 speed
clutch pedal assembly
brake pedal assembly
clutch master cylinder
clutch hydro lines on firewall/passenger side frame rail
dead pedal (if you want one)
Parts from a 92-95 Civic
wires that run from ignition switch to the drivers side firewall main clips running out to the engine including the starter relay switch
Aftermarket parts
Place Racing tranny mount auto to manual
This is just a quick run down. You MUST have the Place Racing mount because the mount on the passenger side frame rail is located higher for clearance due to an auto tranny is much larger than a manual.
From my buddy Brad over at another forum....
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Sep 24, 2002 | 08:58 AM
tbkonwso's Avatar
tbkonwso
omfg 1.2 bar! holy cow!
tranny
shift linkage
shifter
slave cylinder
Aftermarket parts
also a 5 speed ecu and you need yo redo your timing cause auto timming and 5 speed timing is lil diferent
Old Sep 24, 2002 | 09:09 AM
xBaByGrLx's Avatar
xBaByGrLx
Def. don't forget the manual ECU and you need manual axles as well.
Old Sep 24, 2002 | 09:10 AM
xBaByGrLx's Avatar
xBaByGrLx
Oh, and a rear motor mount bracket.
Old Sep 24, 2002 | 09:13 AM
xBaByGrLx's Avatar
xBaByGrLx
And a flywheel..
(any other questions, feel free to ask me, I've done the swap on my Altima, and a few of my boys have done it on their Civics)
Old Sep 24, 2002 | 09:49 AM
HeavyCivic's Avatar
HeavyCivic
Team HighRev
oh i forgot to mention that im swapping out the motor too
Old Sep 24, 2002 | 01:37 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
you don't need that wiring harness from the ignition switch. you just need to splice a couple wires, and get the ecu. Also need flywheel, clutch, and shiftlinkage/shifter.
puffy
Nov 5, 2003 01:05 PM
90_crx_flaze
CRX & Pre 92 Civic
8
Apr 1, 2003 08:47 AM
fastz71
Prelude
8
Nov 21, 2002 05:01 PM
Cosmo M3
Accord
8
Sep 30, 2002 08:39 PM
k.a.y
92+ Civic/EL & Del Sol
13
Jul 11, 2002 04:35 PM
