re B and D series oil pressure sending unit sensors the same?
Old Apr 22, 2006 | 09:33 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Default re B and D series oil pressure sending unit sensors the same?
The one wire sensor on the back of the block where you usually put the fitting to run turbo oil lines. When I pulled my B16 out of the 4 door last week I accidently broke the sensor. I was wondering if I could use the sensor off of my D15 that came in the hatch I bought.
Old Apr 22, 2006 | 09:41 PM
AcuraFanatic's Avatar
AcuraFanatic
Check the part #'s, but I highly doubt it.
Old Apr 23, 2006 | 05:51 PM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
I have one from a b16 for cheap.
Old Apr 23, 2006 | 08:31 PM
raiden571's Avatar
raiden571
turning u inside out
pretty sure they are the same. im trying to find some proof
Old Apr 23, 2006 | 08:43 PM
raiden571's Avatar
raiden571
http://www.partsamerica.com/ProductL...witch%2fSender
same pat no. for a 2000 si and a 95 ex
EDIT: dammit, it wont work right. but compare say a 2000 si and a 95 ex, there the same. i think itll be an ops121 at advance auto, but im not positive
Old Apr 23, 2006 | 08:56 PM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
18479 for the single cam 98' EX 5spdhttp://www.hondaautomotiveparts.com/...+BLOCK-OIL+PAN
99' si
Part Number: 18340
http://www.hondaautomotiveparts.com/...DOHC%29%283%29
Old Apr 23, 2006 | 10:32 PM
Omniscient's Avatar
Omniscient
Could you find out how much they cost Eric? That is if you still work at Advance.
I mean I can probably fix the sensor. The sensor itself isn't broken, the wire got pulled out of the little white plug that goes onto the sensor.
Old Apr 24, 2006 | 09:20 AM
Running925's Avatar
Running925
Your Powder Coater
take a pic.. if your talkin bout the rubber boot.. we cut those off!
Old Apr 24, 2006 | 05:21 PM
Omniscient's Avatar
Omniscient
I took a look at it last night and inside the boot is the single wire with the white slender cap that plugs onto the sensor. The wire was pulled out of that white cap. I thought I actually broke the sensor but I was wrong. So I guess I just need to do some soldering.
Old Apr 24, 2006 | 07:47 PM
Running925's Avatar
Running925
Your Powder Coater
sounds like it.. should be alright.
