One Quick Question
Old Apr 22, 2006 | 04:15 PM
daskid's Avatar
daskid
Default One Quick Question
Does a 1992 Honda Civic Hatchback have the same coil spring fitting and measurements with a 1997 Honda Civic Hatchback? My friend has Neuspeed lowering springs for a 1992 Honda Civic Hatchback and I would like to buy it for my 1997 Honda Civic Hatchback but I just wanna make sure it will fit to avoid waste of time and money. Your response will be truly appreciated. Thanks!
Old Apr 23, 2006 | 06:19 PM
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
The spring rates may be different but if you're desperate for lowering, they'll work in a pinch.
Old Apr 23, 2006 | 08:48 PM
Phateless's Avatar
Phateless
S2K compatible
the spring rates would be stiffer in the newer springs, wouldn't they? because the newer one is likely to be heavier, correct?
Old Apr 24, 2006 | 08:27 PM
daskid's Avatar
daskid
ok. i will just try it out. thanks a lot!
Old Apr 24, 2006 | 08:30 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Yes it will work but the ride will be a little different.
Chefboiali's Avatar
Chefboiali
scrotal surge
The stock struts aren't going to last super long. I have neuspeed springs on my hatch, and my struts are compressed. It's an OK, but lame ride on bumps. The back sounds horrible.
Old May 3, 2006 | 06:55 PM
daskid's Avatar
daskid
LoL! so how can you resolve the terrible sound at the back? so do I need to buy new struts? how about the shocks? do I need to replace them? sorry, im just new at this stuff. so noob.
Old May 3, 2006 | 08:04 PM
Chefboiali's Avatar
Chefboiali
scrotal surge
What I'm GOING to do is buy new struts that are meant for a lowered spring. A shock on a Honda like ours is considered a strut. It's one in the same. It's all going to depend on how much you want to spend. There are a lot to choose from, and everyone is going to tell you what you should get. Do a search on it. Something like "best strut" in the search window. I might do a KYB, because they're been around a long time, and are with-in the budget (when I get around to it). I'll spend like $300 for all of them.
Maybe just throw the springs on, and drive the car. The car will ride differently from the get-go, and eventually you'll notice WHEN the struts are starting to go. When you put new ones on, you'll no longer be a "noob" when it comes to it, and you'll be able to help someone out if you bump into a question like this.
Old May 3, 2006 | 10:41 PM
Phateless's Avatar
Phateless
S2K compatible
find out what springs they are and how much of a drop they're supposed to give you. if it's only an inch or so, you can probably get away with the stock struts for quite a while. if it's any more than that, they'll go eventually. it also depends on your purpose. do you want sport/street, or do you want full race, rattle your balls off on the way to work?
Old May 6, 2006 | 12:37 AM
daskid's Avatar
daskid
i'm starting to get the hang of it now. thanks for the tip. sure i will help someone like me, who is so confused about technical stuff.
i just want it for the looks. just being with a car which is nice to look at makes me feel confident. i just have to install it this weekend. maybe sunday. thanks again.
