Please help me!!!!
Old Apr 13, 2006 | 01:59 PM
njblacksol's Avatar
njblacksol
gangsta pancake
Default Please help me!!!!
hey was up guyz.......i just got a coupe and.... when i keep my car off longer than 15 minutes .... everything resets....in example the clock starts at 1 and all the radio presets reset......do you have the slightest clue why?????
thanx in advance
Old Apr 13, 2006 | 04:39 PM
mishqua's Avatar
mishqua
Little more info plz year? could be somthing silly like bad battery. Not enough to go on though
Old Apr 14, 2006 | 04:00 AM
njblacksol's Avatar
njblacksol
gangsta pancake
ok well the car is a 1995 honda civic ex coupe.....the battery doesnt really seem that bad....it always starts up wit no problem or lag.....but i guess i'll try it....what else could it be?
Old Apr 14, 2006 | 09:58 AM
mishqua's Avatar
mishqua
just wondering do you have an after market head unit, is there an amp hooked up to,also if you have the above two is there a cap involved. Sounds really odd that its only affecting your stereo? Only thing that pops into mind is to trace the wires back and see if ya have a bad wire.I'd say bad ground but u would no cause it would do it will the car was on
Old Apr 14, 2006 | 08:06 PM
njblacksol's Avatar
njblacksol
gangsta pancake
it affects my clock too and i dont have an aftermarket radio.......and i will check that tomorrow ...wat else could it be
Old Apr 15, 2006 | 09:17 PM
njblacksol's Avatar
njblacksol
gangsta pancake
please people i need advice
Old Apr 15, 2006 | 09:50 PM
Musicman's Avatar
Musicman
Never had this prob but was wondering if a failed battery in the cpu being the culprit...if it even has a battery for storing settings..???? Anyone?
Old Apr 15, 2006 | 11:36 PM
Chefboiali's Avatar
Chefboiali
scrotal surge
I'd check my battery cable and all the grounds. Just follow any wire coming from the battery, and see where it goes. Check grounds as well.
Keep a 10mm socket or wrench with you too. If anything is loose, it's more than likely a 10mm bolt. That car has 100's of them. Check your main fuse box, too. Check everything. lol
If you're lucky enough to have an Autozone, I'd take the car there and have them check the battery for you. It's free. I've never had this problem with a Honda, but I've had it on my 67 Camaro. Battery seemed good, but everything would reset for no reason.
Old Apr 16, 2006 | 03:48 PM
njblacksol's Avatar
njblacksol
gangsta pancake
thanx i'll take a look
Old Apr 16, 2006 | 06:07 PM
Seruy's Avatar
Seruy
Check your fuses, small chance but who knows.
