is there a way to wire my headlights...
Old Apr 6, 2006 | 07:11 PM
spanky's Avatar
spanky
I go duffy on dem bitches
Default is there a way to wire my headlights...
so they automatically turn off when the ignition is off and vice versa?
tia
95 civic cx for reference.
Old Apr 6, 2006 | 07:37 PM
Wharbone's Avatar
Wharbone
Don't know how to do that. I made a headlight buzzer from radio shack so I don't leave my lights on.
Old Apr 6, 2006 | 07:38 PM
spanky's Avatar
spanky
i did that in my 94 but i think this might be a bit more convenient.
Old Apr 6, 2006 | 08:22 PM
Fkatz's Avatar
Fkatz
cut the wire that sends power to the switch then get another wire and run it from a fuse in the fuse box that only gets power when the car is on hook this wire to the wire that was cut from the switch and then u should be set
Old Apr 6, 2006 | 09:12 PM
Civic2Scooby's Avatar
Civic2Scooby
this is correct....I ran my wire from the radio fuse to the headlight relay...this way if I turn my car off, the power is cut to the headlights
Old Apr 6, 2006 | 10:30 PM
Kai's Avatar
Kai
Rotorphile.
It would be better to run headlight power through a relay controlled by an ignition "on" power signal. That relay can be rigged into the existing wiring with basic electrical skills.
Old Apr 7, 2006 | 03:06 AM
spanky's Avatar
spanky
I don't have that. h:
Old Apr 7, 2006 | 10:10 AM
Civic2Scooby
my way worked just fine h:
Old Apr 8, 2006 | 01:01 AM
Kai's Avatar
Kai
Rotorphile.
Yeah, but I like relays.
Old Apr 8, 2006 | 08:29 AM
Civic2Scooby
horray for bimetalic strips :wiggle:
