reverse gear grinding
Old Apr 3, 2006 | 12:53 PM
k4rts's Avatar
k4rts
Default reverse gear grinding
almost every time i put it in reverse it grinds. yes i have the clutch all the way in.
Old Apr 3, 2006 | 01:01 PM
might just be ur synchros going bad h:
if u cant fix it right now, try putting the car into 1st, first.... then reverse... that should be a temp fix
Old Apr 3, 2006 | 02:23 PM
JonD's Avatar
JonD
there are no syncros in reverse
before you go into reverse, put it in first or third then go right into reverse, works all the time...
Old Apr 3, 2006 | 02:54 PM
CivicRacr's Avatar
CivicRacr
is the car moving while you are putting it in reverse?
Old Apr 3, 2006 | 03:23 PM
extensioncordy's Avatar
extensioncordy
EG6
mine grinds when im still rolling forward when i put it in. but if im at a dead stop or rolling back it goes in no grind
Old Apr 3, 2006 | 03:34 PM
hence the h: but technically it differs from car to car... some do h:
WTF are u doing putting ur car in reverse while rolling?
Old Apr 3, 2006 | 06:03 PM
remy's Avatar
remy
true allright,i spoke with a mechanic and he said that it is better to first put th car in 1st gear before one goes to reverse ,instead of neutral to reverse!!!
Old Apr 4, 2006 | 08:45 AM
k4rts's Avatar
k4rts
i tried putting it in first, and then reverse. woo! no more grindage
Old Apr 4, 2006 | 11:17 AM
extensioncordy
EG6
i would be rolling slowly forward. then putting it into reverse with the clutch all the way in and it would give a slight grind i was wasnt rolling at a high rate of speed
Old Apr 4, 2006 | 11:30 AM
DragoonRaven's Avatar
DragoonRaven
Unpimp Ze Auto
Mine does this as well; I slightly disengage the clutch and let it grind a little, then try to go into reverse again and it'll work like a champ.
What's actually behind this though? (Hopefully something a new and improved clutch, next on my work list, will eliminate?)
